Help my truck won't start
Richard123
Mulberry grove, Illinois
Ford ranger
So I accidentally hooked my battery up backwards in my 1995 ford ranger. It was acting like the battery was bad weak starting. It blew a few fuses and broke the wire from the selinoid that goes to the alternator. I replaced the fuses and repaired the wire with a crimp connector and put a new battery in. It worked for about a week but still weak starting and now it won't start at all. It clicks the starter like it wants to but won't turn over like the battery is dead. Battery says full charge when hooked up to a charger but is low on the gauge when I turn the ignition on. I'm guessing starter or alternator but I'm far from a mechanic I'm just a shitbox enthusiast that can turn a wrench and follow instructions lol. Please help this is my daily driver.
rusty ol ranger
2.9 Mafia-Don
7,745
Michigan
177 CID
Get the battery load tested.
rusty ol ranger
2.9 Mafia-Don
7,745
Michigan
177 CID
It was 12.8 when I was messing with it last night.
Yeah but whats the voltage drop to when you try to crank it?
Having it hooked up wrong coulda cooked a cell or something.
gaz
679
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@Richard123
Replacing the wire that you repaired may be what takes; if I have the right wire in mind it is 12g-ish stranded copper wire, an Al crimp is not going to conduct current as well.
rusty ol ranger
2.9 Mafia-Don
7,745
Michigan
177 CID
superj
2,722
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
did you replace that wire? did it fix it?
No members online now.
