jim cafarelli
- Jan 19, 2010
- Reaction score
- 0
- Location
- Valley Center,CA.
- 2000 2wd 5spd 4
- Make / Model
- FORD
- Automatic
I just bought an explorer disc brake 373 appeared to be limited slip by turning the axle on the bench both spin the same direction,anyway pulled the cover don't see any clutches appears to be and open carrier but appears to be locked and work like a posi so I pulled the center pin pushed in the drivers side axle no problem and removed the c clip but on the passenger side it wouldn't slide in enough freely so I had to tap it in with a big hammer to get the c clip out and use a big slide hammer to pull the axle, it appears to be a press fit into the carrier...can anyone shed some light on this for me? Thanks ahead for any help
