- Aug 31, 2021
- Reaction score
- 974
- Location
- Roanoke VA
- 1997 and 1999
- Make / Model
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
2002 Lexus RX300. 265,000 miles. V6 VVTi.
The top pully for the timing belt was squeaking so I assume its bearing is shot. Also timing belt looks original. So, obviously, replace timing belt and that pulley.
Question is, how does the top pully get replaced? Do you have to pull it somehow or is it part of another assembly? Hired wrench said get timing belt "and components" wtf. I asked him again and he says "the belt pulleys and basically anything involved with the timing belt" that doesn't help me much.
Probably replacing water pump too because of the miles even though it's not leaking, seems wise (?). Maybe the -lower- timing belt pully is part of water pump? Do I need something else for the top pulley (squeaking one)? In short if I'm doing timing belt and water pump, what else do I need to put timing belt and "and components" up to snuff?
She does pretty frequent 1000 mile round trips so it has to be as reliable as I can make it.
