**HELP** Turning ignition clicks, and then kills all power to interior, does not start or turnover
sauceman
15
Ford Ranger XLT
Hi guys, I am having trouble with my 2000 Mazda B-series, 5 speed. I tried to start the vehicle, but it does not turnover, It has power until I push the clutch in, and turn the ignition key, it makes a single loud "click" and then the power shuts off. I have tried a brand new battery, which didn't work. I'm on a tight budget, so I am trying to avoid taking it to a mechanic, so any help is appreciated.
rusty ol ranger
2.9 Mafia-Don
7,616
Michigan
177 CID
Hows your terminals and connections look?
Thats 1st thing id go through.
snoranger
Professional money waster
ASE Certified Tech
13,716
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
This...
Check you’re battery cables. Both at the battery and at the starter/ engine side. You’re looking for a loose, corroded, or bad connection of some sort.
8,372
+1 ^^^
Remove and clean battery cables, BOTH of them
Colin
182
ON Canada
Mazda
Can you bump start it?
sgtsandman
Aircraft Fuel Tank Diver
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If those check out. Start checking for bad grounds to the block. This is assuming you have already confirmed that the charge on the battery is good.
sauceman
15
Ford Ranger XLT
Hi everyone! Thanks for the replies. The source of the problem, was due to loose battery connectors. I sprayed the connections with WD40, and then I tightened them up more, for a secure connection. This solved the problem, and it started right up.
