Help with tranny swap, what fits?
85Diesel
Hi there,
I have an 85 Ranger reg cab, short box 2.3L turbo diesel with manual trans (2wd). The trans lost 2nd gear and I am wondering what will swap. I hope I can find some more info here as I have already looked at the Tech section.
I have two choices:
1) use TK 5spd 2wd from my donor 86 supercab long box 2.9L??
2) buy a donor truck that I could use all the 4x4 gear from the clutch to the wheels and bolt on. (from what I can find, I would need the FM145 transmission???
I hope someone can help me with this please!
Jessekustoms
2x1997 2.3 2wd
Should have a Mazda m5odr1/ hd do you still have a door code?
Hitchner2009
Silverdale, Washington
If your looking for a straight swap, the Toyo Koygo will be better off than the FM145, as it is able to withstand more Torque and demand. The Toyo Koygo is a pretty good transmission.
The FM145 is what i have in my ranger. And i have a 87 ranger 4x4 that originally had the old cranky 2.9 but swapped to a 4.0. FM145 is a good trans too, only problem i have ever ran into was when i rebuilt it, i had to get an update kit for 5th and Reverse because one of the teeth off the gears broke off to a manufacturer fault, the update kit fixes this. Only thing i have ever ran into with it. Hope this helps! Let me know what you choose! Good Luck!:beer:
8,372
The original post was from 2007 :)
Hope he has done the work by now
Hitchner2009
oh dear god hahaha, how the hell is it still at the top of the board then? lol
8,372
Jesse posted so it came back to life :)
turbo91xlt
63
Goshen, NY
1992
m5od wasn't introduced till 1988 and only then in was behind the lima 4cyl (2.0l, 2.3l) gas engine for that year.
