Hi! I need advice! My truck wont start.
Coloradogirl
Colorado Springs CO
Ford F150
I use my truck pulling a 16 foot fully loaded trailer with no problems except it has no power up hill, but when I got home I turned the engine off and it never started again. It acts like it is out of gas but is over half full. I put in new fuse, relay, filter and pump but still not starting. No noise frimt the pump with the key but some gas from the pressure valve. Getting ready to change the csc sensor but is ther any other ideas I should consider. No warning signs befor issue.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
That era f150's are notorious for the fuel pump driver module going bad. But stop replacing things and do some tests. First, do you have an obd2 scanner? Can you pull any codes? A fuel pressure guage would also help (truck doesn't need to run to test pressure). A simple free-ish test. Spray starting fluid down the intake tube, if it starts you've guaranteed its a fuel issue.
Coloradogirl
Colorado Springs CO
Ford F150
I do not have a scanner but the only code that showed up when the check engine light came on was a missfire in the 5th cylinder. Which I new about because of the rough idle. I did try the starting fluid and yes it starts as long as it is being sprayed but stops immediately when the spraying stops. I did not change the sensor because I don't believe that is the problem. I think it is something electrical because even though there is a small amount of gas from the pressure valve it doesn't look right and the fact I do not hear the pump engage when I turn the key tells me there is probably an open some where in the electrical going to the pump, but I absolutely am terrible with electrical and have no diagnostic tool for it or know how to use them right now. I haven't checked for spark yet either, but am still focused on the fact I don't hear the pump!
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
i NEED AN ADULT! HELP!
rusty ol ranger
2.9 Mafia-Don
7,759
Michigan
177 CID
Since it runs on starting fluid its definatly a fuel issue. So youre on the right path.
Im not super familar with the Fseries post 96...but you dont have any other weird issues right? That might point to a bad ecm?
Also remember that just cause you installed a new pump doesnt mean that its a good pump. Espicially if you ordered an amazon cheapy or something along those lines.
The fact it was running though then wouldnt restart after shutdown leads me to believe it wasnt the pump..,.it could be but a pump woulda just quit regardless.
I have heard of the "fuel pump driver" in those year trucks but know nothing about them. Maybe @adsm08 or @RonD can shed some further light on it.
3,614
At the rear of the truck, mounted to a frame cross member just in front of the spare tire is a small electronic module. It has a large plug, a black plastic cover, and an aluminum body.
Remove it and inspect the side facing the frame. It probably has a hole in it. That's the fuel pump driver module.
Coloradogirl
Colorado Springs CO
Ford F150
Thank you all! That s awesome I didn't even know about that! I am going to do that today and hopefully that is it! Will save me tons of $$$$. Was scheduled for a tow and shop next week.
Coloradogirl
Colorado Springs CO
Ford F150
Mine is not there. I know it is supposed to but it isn't.
Coloradogirl
Colorado Springs CO
Ford F150
Is there al alternet place we'd not for tha fpdm? It is not in front of the spare tire on my truck. Some where I read something about behind the driver and back passenger seat. But that description was too vague. I probably can recognize it from all the videos I watched trying to find another place to look with no success.
rusty ol ranger
2.9 Mafia-Don
7,759
Michigan
177 CID
First i found this....
But then i found this...
Looks like its between 2 crossmembers dierctly across from one of the rear wheels. Pic description said 02....but i imagine should be the same
3,614
Congratulations. You found the FPDM.
Take it off and look at the big hole in the back of it.
Then do NOT buy the Dorman replacement that bolts right back on to the frame. Spend a few extra dollars to get the Ford one. It comes with stand-off bolts that will move it off the frame about a 1/2 inch so that it doesn't collect crap and rot out.
rusty ol ranger
2.9 Mafia-Don
7,759
Michigan
177 CID
I found that pic....
On google.....
She said she was unable to locate it on her truck.
Coloradogirl
Colorado Springs CO
Ford F150
Well I gave up and had it towed yesterday. And when they were moving it down the driveway to load it the power steering dumped all it's fluid onto the ground where that forced it to turn and it got a flat tire somehow while loading! I did try looking everywhere for the fdm it must de well hidden in that spot. Oh well I guess they will fix it.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,785
Wellford, SC
6"
These trucks will sometimes puke power steering fluid when you turn the wheels with the engine not running. No big deal. Check the level and add as needed when you get the truck back. I don’t have much faith in your towing crew, though. They should not have caused a flat tire.
I hope the shop gets your fuel issue fixed for a reasonable price.
