okay, maybe we need a simpler example.
When you follow a semi-truck closely on the highway, your vehicle doesn't use as much gas because there is a slight vacuum or low pressure behind the large truck. In fact, we used to ride our bikes up 10 feet behind the semi's and turn our ignition off and leave it in neutral because the vacuum would pull us and keep us right up there. Anyways, this is a simple example of low pressure, or even a slight vacuum is created when there is an obstruction infront. Now, instead of a semi on the highway, lets say the obstruction is the headlight. Now, we have an intake directly behind the obstruction, which is our headlight. This is the same exact effect.
I am willing to bet a 3"x14" hood scoop will hardly affect wind resistance and aerodynamics. I think you're just starting to nit-pick.
There's more to a cold air intake than a fancy air filter (at least a quality one). A quality cold air intake will not only have a high flow filter, but it will use a box and seals to keep out engine bay temperatures. It will also use a larger diameter intake tube with smooth mandrel bends and as few as needed. The CAI will also have a thick plastic or insulated tube to further keep the intake charge cool. I doubt Ford (and other companies) would produce such an intake if it was not better than the factory one. It costs more for R&D to produce, and horsepower talks. So if these mods were infact dropping hp figures, they wouldn't use them. Hell, K&N figures show a 5hp increase in the rangers, with no other mods. I'm really sorry, but the whole "ford only uses it because it sounds cool" sounds a lot like previous posts like "ford only installs overdrive because it appeals to customers". I bet there's more reasoning for ford to produce a CAI than "It looks cool".
