Horrible pinging
Mr99Ranger
West Virginia
2.9
My dads isusu trooper with the 3.2 dohc v6 makes an awful noise sort of like a SUPER loud ping anywhere above 2500 RPm. Its worse on hills and only does it when the engines under pressure, not when revving in neutral, etc. Its constant at interstate speeds and i know it cant be good but cant figure out the problem. Any ideas?
The_Dealer
10
Macon, GA
Duh!
buy some maf cleaner if it has one and clean it, replace air filter, fuel filter. if that dont work try octane boost or higher grade fuel
def. do a seafoam treatment through the intake
yup its pinging. my 2.3 ranger did it till i did all of the above. reccomend seafoam first
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
try cleaning the maf and iac, check the spark plugs and wires, also check the octane on the fuel its using, mine did it before tuning it up and when the iac mas messing. when i use non premium starts with the ping again
daniel3507
74
NE Oklahoma
2.3 EcoBoost
Ive dont all that and mine still does the exact same thing only i wouldnt call it super loud. Ive tried to clean the IAC but have not replaced it.
Twisted_Steel
Burlington, NC
302 HO
How many miles? How much oil pressure? Worst case scenario, could be bearing rattle under load.
The_Dealer
10
Macon, GA
Duh!
also if its a manula trans could be the clutch system making noises
