horsepower needed
kunar
131
Toledo, Ohio
5.8l
hey i'd like to apologise for any frustration/confusion as to what was said yesterday from this account. My little brother i guess made an account on here and clearly was talking smack about my truck. Here is the truth behind my truck its a 93 ford ranger 4x4 xlt super cab. Pretty close to stock i got 33x10.5x15 dunlops and a 3" body block with true dual complete exhaust (mostly custom minus headers and mufflers flowmaster 40 series) have a chip on it and msd ignition other than that the truck is more or less stock
even though i dont really believe you... thanks for the apology. stick around a while, you may learn something. most of us are really easy to get along with, i swear :icon_twisted:
now back to the OP> theres not much you can do to a 2.9 other than swap it out. like has been said, your best bet is a manual transmission and lower gears to get the most out of whatever engine you end up using. you can bolt on a thousand dollars worth of junk and still not have a real power maker. depending on what youre using it for, maybe a better option would be a 2.3t swap
almostclueless
screw that, ban him anyway just for entertainment's sake
he's probably bs'ing about how his little brother was rude
turbo cat
city of rain wa
exploder
4.0ohv turbocharged
wether hes BSing or not dosent matter hes not claiming to have a 330 horse 4.0 anymore is he. 330+ horse can be accomplished on a 4.0 but i ttakes 15psi from a turbocharger and at least a mild cam to help with the flow and then tuned and fueled correctly.
HndMeDnBroncoII
Pitt Meadows
BroncoII
2.9
guys what can i put on my 2.9 87 bronco II to help the hp and i want to do a 4.0 or 5.0 swap not sure yet
try the k&n air filter the whole kit if you can afford it but the filter alone will help when was the last time the ignition module was changed
just because it works doesnt mean it is performing at peak efficiency
same with wires the plugs dont have to be outrageous just decent quality
i have had good results with the motorcraft plugs
also look into an underdrive pulley set they are liked and disliked about the same do your own research there.the principal is the smaller pulleys way less belt drag engine spins easier.
check your timing chain as well might be stretched if it is original
clean your throttle body
the factorys do a fairly good job of tuning these motors already and just cause the parts can endure for twenty years like my b2 doesnt mean they are not old and worn and gears would be perfect too
let me know how it goes
btwMy seven year old daughter could bullshit cars and trucks better!:icon_rofl::icon_rofl::icon_rofl::icon_cheers:
