how do I check my valve guides??
baconops89
California
2.8
I am in the middle of changing the valve stem seals on my 85 ranger 2.8 and I got to thinking. This truck is really old how can I check the valve guides too? So does anyone know how I can check my valve guides without pulling the heads?? Any help is greatly appreciated
8,374
No, there is no way without removing the valve, and the other side of that is what would you do if one did test bad :)
Valve guides rarely wear out, the seals do.
Just replaces the seals and oil burning will stop
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
I don't see how you can.
The clearances are so small that you can't measure them without taking the head apart. Just replace the seals, if the guides/valve stems are too worn, you will wear out the new seals in pretty short order. And you will be back to where you were before you replaced them.
It could be months, it could be years!!
baconops89
California
2.8
OK thanks for the replies. at least now i wont be so worried that I'm replacing valve stem seals with worn out valve guides.
baconops89
California
2.8
I got half of them done without much trouble. The old seals were shot. Dried up brittle and shrunk.
