How have y'all mounted your front extended brake lines?
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i have the James Duff kit that ive had on for a while now (believe its for 4-6in, i have 4in lift) i have mine routed around the coil behind the sway bar, i got them to stay like this by zip tying them to the coil and sway bar for a month or so. Ive had them like this for a while but I dont like the routing and they have been knicked in action several times and have covered them in 1/4in wire loom since. (picture is hard to see but driver side is easier to tell what ive done) Was hoping to see if anyone had come up with a good solution as i dont believe the oem lines have anything keeping them in place except for the hard portion. maybe later model trucks had brake line mounting spots that i could take advantage of?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,536
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
My Bronco II has it zip tied to the spring. I'm not fond of it either.
I remember seeing @tw205 solution to this. Might have been over on the Bronco Corral. Maybe he can share it here?
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
The extended brake line I bought came with mounts. I first put them on the factory mounts but they stuck out horizontally. Factory lines have a hard bend and point down. I put on the mounts that came with the brake lines and pointed them down. I’ve just started driving this truck a little so don’t have any feedback on and rubs on nicks.
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
My "factory" lines came with a clip in the middle that I assumed was meant to attach to the coil spring. It looks something like this:
Of course it doesn't fit around the spring...
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
I used the '95 suburban brake lines but I just zip tied them to a center coil on the springs, been like that for like 12 years now and haven't had any issues
