greaseyfingers
- Nov 4, 2007
- 1
- Age
- 52
- Crookston, Mn.
- Ford
After reading the information procedure on Removal Of Carrier And Slip Yoke:
How many bolts are there securing the carrier to the support arm..
Is the support arm that they're referring to, the axle arm, on the passenger side, which connects the twin traction carrier beam to the frame's cross member, where the axle arm is attached by a threaded section going through a big rubber hole and held together with a pretty large nut, about 7/8" in size..
Where is the shear bolt located, securing the carrier to the axle arm, which it says to tighten to 75-95 ft. lbs.
And is it just one bolt they're talking about..
I'm hoping, you'll explain this in a more understandable way, than the information that I read below..
1) Jack up the vehicle, secure it on jack stands, and remove the front wheels.
2) Remove the nuts and U-bolts connecting the driveshaft to the yoke.
3) Remove the spindles and axle shafts as described above.
4) Place a jack under the carrier. Remove the bolts securing the carrier to the support arm. Separate the carrier from the support arm and drain the carrier.
5) Rotate the slip yoke and shaft assembly so the open side of the snap ring is exposed. Remove the snap ring from the shaft.
6) Remove the slip yoke and shaft assembly from the carrier.
7) Remove the oil seal and caged needle bearing.
Installation:
1) Clean and inspect the bearing bore. Drive the bearing in until it's fully seated in to the bore.
2) Coat the oil seal with multi-purpose grease and drive it in to the carrier housing.
3) Install the slip yoke and shaft assembly into the carrier so that the snap ring groove in the shaft is visible.
4) Install the snap ring in the groove and make sure it is completely seated in the groove.
5) Clean all traces of gasket sealant from the mating surfaces with lacquer thinner or gasket remover. Apply RTV sealant in a 1/4 inch wide bead. The bead should be continuous and not pass through or outside the holes.
6) Position the carrier on the transmission jack and install it in to position on the support arm. Use the guide pins for alignment. Install and tighten the bolts to 40-50 ft. lbs.
7) Install the shear bolt securing the carrier to the axle arm and tighten to 75-95 ft. lbs.
8) Install the shaft, joints, and spindles.
9) Connect the driveshaft. Tighten the U-joint straps to 8-15 ft. lbs.
10) Fill the carrier with Hypoid lubricant. Trak-Lok limited slips add 4oz. of friction modifier.
11) Install the front wheels.
Installation:
