How long has it taken you to lower your truck?
littlered351
I just got my DJM 4/5 lowering kit for my truck. Was just wondering how long it's taken you to lower your truck?
GaryC
Hi There,
I just did mine. I am somewhat mechanically inclined. Own a minimal amount of tools. And I worked around my work schedule. My truck was in my garage for 4 days. But my family was out of town so I had use of my sons car. 13 hrs total time. That's by myself. 3 hrs after work. Then 3 hrs before work and 2 hrs after. Then on my day off 5 hrs to complete. The next day I took it for alignment. You need at least 2 good jack stands and a good jack. After doing it once I am sure I could do it in one 8 hr day. I also bought the eccentrics for the upper control arms. And I also bought new steering end links. I also threw in new brake pads while I was there. Good luck! It rides great and looks so much better. I do get a little rubbing on the drivers side. But I'm running stock 225/70/15 right now. It actually looks good with the stock chrome wheels.
ES894x4
December 2013 STOTM
MTOTM Winner
5
i bought 2" roush springs 2 year ago when i got the truck, i still havent put them on haha
Hazmat Ranger
May 2009 STOTM
MTOTM Winner
40
North Texas
4.7
I did mine separately - rear first and then the front. The axle flip probably took around 2 hours and the front took about 4 since I was working by myself on both. The front also need more coercion to break loose the king pin bolts. So 6 - 8 hours alone is not a bad time - with help and all the right tools/experience it might not take as long.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
first time I lowered a Ranger was a '94 with twin i-beams, we did a 5/7...took us a full week working nights on it. Only because it was rusted together pretty good, and me and my friend were both pretty young and didn't have a whole lot of experiance with that stuff..final product looked nice though!
I now own this truck (its the one in my avatar)
Insanejughead
33
Missouri
'94, '86
2.3T
6 hours for me given that I have another person to help move the rear axle around. Other than that part... I could get it done in 4 hours (also given that there's not any of that "impossible" rust going on."
Oh, and I HIGHLY HIGHLY recommend a tow ball wrench for all those guys with I-beams. They're perfect for getting that suspension apart since each end is the right size (1 1/8") for the radius arm bolt (that foot long bolt that usually rusts in place) and the other end is perfect for the camber/caster adjusters (1 1/2")
sacredauto
hampton roads, VA
none...currently
it took me about 7 hours with a lift to do my 4/5, 45 minutes getting the truck centered perfectly becuase the frame rails are just too narrow. and it was my first time doing anything like that and i was taking my time.. if i had to do it again i could probably do in in 4 hours easy
rangerpimpn84
castile, new york
2.3l
It only took me and my ranger buddy josh 6 hrs front and back. The whole job shouldve taken 4 but we had to reverse the shackle flip and he had never dropped a truck ever. I couldnt have the ranger riding on bump stops in the back. I never thought that i would be that low. Needless to say im addicted im notching the frame next.
rat_ranger
December 2009 STOTM Winner
MTOTM Winner
moving with the army
2.3 duratec
took me 2 days. but I also changed the headlights, blacked the tails, converted to cobra brakes, added a lip spoiler and short throw during that time frame.
JoshT
1,924
Macon/Fort Valley, GA
So far I've been working on it about 2 months. Currently I only have the entire front suspension ripped out of the truck. Between my work schedule, school, and doing it all my self, I might only have a couple hours in it total. I literally might have time to remove a bolt then it will be a week before I can work on it again. Currently I have to separate the knuckle from the I beam because I forgot to break the nuts loose before I pulled everything apart. Then I'll send the springs off to be sand blasted and possibly powder coated, I may also have the knuckles done. Everything else will be cleaned up and painted with satin black rustoleum.
Army
2.3
Took me 12 years :D
I cheated and took the beams and flips to Tire-Pro and had them do it, while I got new brakes and tires too.
littlered351
Finally got mine lowered. Took about 11 hours by myself with hand tools. Like most I think I could do the next one in about 6-7 hours. I had to swap rear axles and front spindles since I was taking out a lift as well as lowering. I still have to take out a 3'' body lift to get it at it's final ride height.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
4,703
woodhaven mi
FORD mostly
BIGGER
sawzall?
bout 10 minutes to take the 44's off and put the 33's on....with the impact....hand tools takes a few minutes longer......:)
kenvb
Whitecourt Alberta Canada
2.3
how long to lower your ranger
took previous owner 1 case of beer and a telephone pole on the roof, its lowered about 2 ft now. LOL
anyone want to buy a slighty mushed 83 Ranger Diesal ? cheeap
bagdranger
Memphis, Tn
2.8
I'm down. I can find a new cab for one. lol
As for me I've been building mine for bout 6 years total. So far I've got full air ride and looking at goin extreme with the suspension soon. Includes ditching the ibeams for a more suitable suspension for bags and custom rear setup. :icon_welder: Then I got a very VERY good idea for a motor swap, but I'd tell you but I'd have to kill you. :D
