- Aug 19, 2001
- Reaction score
- 584
- Location
- So. Calif (SFV)
- Make / Model
- Bronco II
- Engine Type
- 2.9 V6
- Engine Size
- 2.9L V6
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 35x12.50R15
Did you put the STX drop pitman arm on it? If not, then I'll bet that could have contributed something to it rolling over.Using a 91 rollover I put an 87 stx hirider lift on it and checked/replaced worn suspension and steering parts.
If you did put the arm on, then (without seeing it) I guess don't really have an answer other than an issue with suspension tuning maybe. I know desert guys push these suspensions to the limit and aren't having too much issue with it... (this in spite of doing cut & turns on their beams which significantly increases the jacking leverage on the suspension due to it raising the TTB pivot points higher).
