How To Adjust Camber After 2 Inch Drop???
SykoRanger88
Purcellville VA
2.3l 4cyl
my truck is 2 inches lower in the front now from cutting the coils and the camber is way negative, how do i adjust them back into spec? can i just make an adjustment or do i gotta buy a bushing kit or something? thanks.
Yvan
St-Romuald, Qc, Cdn
2.9l.
With a 2 inches drop i'm not that you can fix your camber with the factory bushings, but the best way to now it, its to send it to the alignement ans they will tell you.
sean9721
Heard County, GA
2.3L
Buy some adjustable camber bushings. I have some +/- 3.5 degree bushings that I bought from Advance for $19.46 a piece. They also sell +/-4 degree bushings but they are $35 a piece. Napa also sells the bushings but I dont know the price. And Advance will have to order the bushings. Mine came in the same day though.
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
check out the "camber eccentrics" thread in the 2WD Suspensions sub forum.......it's got lots of info!!!!
5
In the Middle
Gonna get a 460
A friend used these when he lifted his truck, I think will work for us too... the Napa part number is NCP 2643950 and they are $31.99 each.
SykoRanger88
Purcellville VA
2.3l 4cyl
so then i just need to go to Napa, Autozone, or Advanced or something and ask for +/- 3.5 bushings and i should be fine?
sean9721
Heard County, GA
2.3L
Yes, or may ask for the +/- 4 degree ones.
doorgunner
MTOTM Winner
516
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
yep, and if you do any more suspension work to the front end.....all you gotta do is re-adjust the E. bushings!
:yahoo:
Z3CHYD
U.S. Military - Active
17
Lancaster, PA
3 front 5 rear
225/60R15
I did the same to my ranger, i bought the 3.5 degree bushings, took it to an alignment shop and had it aligned, now it steers fine and doesn't wear the tires out, but the ride does get a tad rougher
Z3CHYD
17
Lancaster, PA
3 front 5 rear
225/60R15
here's mine installed
just loosen the side bolt holding the eccentric tight, wiggle the old one out, and put the new one in, and of course align it
doorgunner
MTOTM Winner
516
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
wish I'da invented that thang.....
SykoRanger88
Purcellville VA
2.3l 4cyl
alright cool ill ask for the 3.5 ones, thanks for the picture also.
SykoRanger88
Purcellville VA
2.3l 4cyl
im kinda confused, are you sure your suspension setup is same as mine? i looked all over my trucks spindle area and stuff and i couldnt find anything that looked like what you took a picture of.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
SykoRanger88
Purcellville VA
2.3l 4cyl
wow like 40 bucks a piece wtf...i hope autozone,advanced or napa has what i need hopefully for less.
