How to avoid bleeding clutch slave after engine swap or clutch replacement.
wrenches59864
ronan,mt
2.9
Hi, I don't know if anyone has posted this before but here goes. I see a lot of tips about bleeding clutch slave cylinders on older Rangers but I haven't had to yet. Instead of completely removing the transmission from under my truck, I lower it on the jack, slide it back, raise it up out of the way. Then use a good set of ratchet tie-downs to hold it up between the frame rails. I then have plenty of room to safely do my work. I am sure a lot of you have already figured this out, but I thought some less experienced people might benefit from this tip.
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Good tip, thanks
xcross
Will take not of that! Thanks for the excellent tip.
