How to unscrew?: EGR line to EGR valve('91 2.3)
k3eax
I need to replace the EGR valve but despite efforts I cannot break-loose the nut connecting the line to the valve And yes, I've tried PbBlaster, etc.
I've thought of cutting through a portion of the line near the connecting nut and "splicing" on a new section of line with its connecting nut. This however, I'd like to avoid.
My predicament cannot be unique in the annals of Ranger ownership andso I'm hoping to hear of a solution from other who've had the same problem.
Al
black_demon69
142
AZ
4.0l
Al
try getting egr really hot (red hot) all the way around threads it should break loose then.. when putting new egr on use antiseize on threads..
k3eax
Thanks B-D for taking the time to reply. I thought of "cherry-ing" the nut but applying a torch would be too risky as their there is much nearby that is is electrical and alloy.
Heat is the way to go man. And you don't want to cherry the nut, you want to cherry the body of the valve.
If you are afraid to get a torch in there just run the engine. It will get plenty hot.
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've heard of, but never tried, a freeze spray that might help shrink apart the pieces after being heated up by running the motor.
black_demon69
142
AZ
4.0l
its called water:D:D
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Derf_the_Mule
SouthWest Florida
I recently removed the very stuck EGR nut on my 2007 Ranger 3.0L and last year I removed the very stuck EGR nut on my 1998 Ranger 4.0L using the same method listed below. I have used this method to remove many stuck bolts when a mechanical means to press (or bang) it out was not available to me.
--Spray with PB Blaster.
--Let sit, believing it will work this time and it didn't last time.
--Bang knuckles, cuss, scream, get biggest wrench I can find while wasting time and energy.
--Use can of refrigerant (spray air) upside down to freeze EGR and nut. (Don't use the stuff with bitterant added. You will regret it.)
--Wait until I calm down.
--Use large wrench to break nut loose. I used ~9" Channel Lock pliers. (I had to loosen the power steering reservoir on the '07 3.0L to get enough room for my pliers.) I used larger pliers or a large >12" pipe wrench on the '98 4.0L. It hadn't been removed ever.
I use the DustOff Brand FGSR with the Chrome valve. The cans with the plastic valves have bitterant added to discourage huffing. If you spray it out liquid the bitterant will stick to your skin for days and engine components for months and may make you gag. And when you touch it later it will again stick to your hands for days. Ask me how I know.
You could try using propane, but that is extremely dangerous.
Good luck busting those knuckles!!
