huge oil leak!!!
88ranger2.95sp
2.9
ok my dipstick is pissing oil.... yes ive posted other times about this but im still lost!!! its pressed into the block adn i need it out...
but... i can buy one froma 68 through 84 ford small block at a local auto parts store..
DOES ANYONE KNOW IF IT WILL FIT????
thanks in advance for help!!
Natedog
5
CA
Don't know if it will fit, but where in the dipstick exactly is it pissing from? Where the stick goes into the block just above the oil pan rail, is the dipstick tube cracked, pissing out of the top of the dipstick tube or what?
88ranger2.95sp
2.9
its cracked along the bottom near where the engine block meets the tube...i think... im nearly certain.. i'm nervous that if i pull it out, it will snap and i'll be screwed... if that happens, the only thing (which i know is a very bad idea) is to plug it, and just change the oil regularly... but i really dont want to do that... any suggestions??
soylent_green
If it snaps off when trying to remove, find a bolt and screw it into the hole, tight enough so you can then pull on the bolt, and the rest of the tube will be pulled out by the bolts threads.
Take your time finding the right bolt. Not too big that you risk cracking the block, and not so small that it wont grab.
soylent_green
The dipstick tube for a small block ford will probably fit in the hole, but the legnth and depth of the dipstick probably will not be the same.
88ranger2.95sp
2.9
thanks for the help!!
88ranger2.95sp
2.9
Wow Im Sweet
I Fixed My Oil Leak By Putting A Steel Tube Mated With Rubber Tubing And Hose Clamps And A Stock Dipstick With Jb Weld On The Section Where The Block Meets The Tube... Doesnt Leak A Drop Its Awesome Its Never Not Leaked Before
Natedog
5
CA
Cool, glad to hear you got it fixed.
