I am looking for 5 of these wheels please help!!!
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Prefer a set nearest VA as possible, I will need 5 of the wheels. I want the original triangle window not new D window wheels.. 5x4.5 15 or 16 do not care obviously I know original would be 15. Hope no one on the other site cares I stole this picture for reference...
62750
17,953
SW Iowa
FWIW they were never factory but where a common upgrade.
You can get new ones if you can go a little wider:
Most first gen factory wheels were like 6 to 6.5" wide.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
I can definitely go wider well will be able to but was hoping for the original ones less the stripes. I know its minor and pointless but hey... it was worth a shot lol I can scuff them off and spray them or just leave it alone as I'm sure they'll be scratched up shortly after install..
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
gaz
672
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
RumPunch;
Very common from Les Schwaub, Discount Tire, any over the counter tire joint but I would consider getting them in 15"x8" as that is a very useful platform that you may never outgrow ..)
I found a set used back in 1992-3 and am still using them, very flexible (utility wise not weak.metal wise).
