TimDog
- Oct 13, 2007
- 0
- Age
- 49
- FORD
Hello,
I am having issues with my 1990 ford ranger, 2.9L V6 Manual Tranny, 126000 miles. Hope someone can help me. You guys have come through in the past and I am praying you can help again.
Heres the deal....
First, my truck runs great when its cold and been sitting overnight, around 30 minutes of driving, it starts acting up. Second, failed HC emissions test at idle, passing is 220ppm, reading 1475ppm. On the top end, it tested out fine, no problems This was tested before idling problem progressed into below problems.
The engine accelerates fine, no loss of power, but when I let off the gas in gear, the tach starts jumping and the engine sputters and pops, I can hit the gas again and it returns to normal. As long as I am accelerating, no problems. Check engine light would come on and off, but never just stay on. I come to a stop light, and put in N, sometimes it returns to idle with no problems, but more time than not, it dies. I have to restart the engine, then it will die again, after three or four times of this, I can get it going again, then it repeats the process. Bottom line, it wont stay running, when it does, its maybe for 20 seconds or less. When it does idle, its rough and jumpy. In addition, I have had no reduction in fuel mileage. Runs great on the freeway, no problems at all.
Here is what I have done.
Put on code reader - code read TPS sensor, bad. Replaced, fixed check engine light problem. other codes included MAP sensor not reading correctly, replaced, no change. Still same issues.
Replaced cap and rotor and spark plugs. Checked all plugs, all burning clean.
Still same problems.
I hope i have provided enough information for someone to begin to help. If there are any questions, please ask.
Thanks for all your help
Heres the deal....
