Junk Collector
Truck of Month
- Mar 4, 2008
- 4,805
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Here's what I've been up to. I am painting a different hood. The one I used had a ton of hail damage that I did not fix very well... I had another hood on hand that also has some dents but a lot less of them. I fixed a couple bigger dings and decided to just use filler on the hail, it won't be perfect but should be way better than what I had before.
This is what I'm unhappy with, my current hood has a ton of spots I missed or didn't use enough filler in and/or enough primer. Ignorance on my part, I only had maybe 1 or 2 coats of primer on here and it was not high build. Filler soaked it up and so I have these rings. No big deal, as I have said this was an experimental truck so I don't mind redoing some things just for the practice.
