I cant bleed my brakes
it-broke-again
I have a 2002 Ford Ranger 4x4 4.0L automatic. I replaced rotors, calipers, pads, drums, shoes, hardware, wheel cylinders, and all of the lines from the master cylinder back. I have tried just about all I can to bleed the brakes on this dang thing and still am having no luck. from what I can tell im getting fluid to the abs unit but nothing coming out of it. anyone have any suggestions because the trucks been down for 2 weeks now all because the brakes need bled.
ANY HELP OR SUGGESTIONS APPRECIATED
ford4thot
I'm no expert. But maybe the ABS unit is bad?
it-broke-again
All of the abs worked before I did the lines though so I wouldn't think it went bad
Sent from my XT1028 using Tapatalk
black_demon69
142
AZ
4.0l
try to gravity bleed it will take awhile or get a vacuum bleeder or try bleeding the abs unit on the lines from master first then lines going out to the wheels
these would be the only suggestions i would have at this point
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
I would find a friend to help you bleed the brakes. Have him/her pump the peddle 6 or so times then hold it and crack the bleeder.
If you replaced all the lines it may take a while to get fluid down to the wheels. A second person or a pressure bleeder is likely needed here.
twfmvm
When i replaced the front brake hoses on my 92 and bled them my master cylinder went out. I could tell it was getting old, it was dirty as all get out. Ive heard it happens a lot when you bleed an old master, it busts a seal. And i wish i hadnt wasted so much time trying to rlcheck everything else.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Go buy a qt of brake fluid. Fill the MC to the brim. Hopefully, there isnt air in the ABS I avoid that whenever possible.. Next, start looking for wet spots Check all couplings for tightness. Yeah, I know, you checked, but is everything back where it came from? Are the calipers on their correct sides. If they go on upside down, they wont bleed. I do brakes as needed. I use a gravity bleed after I have opened the system. It wont bleed if the lines aren't tight. If it doesn't bleed, I check my work until I find the leak. :D
naford
12
Can you bleed the abs unit without the computer software to open and close the valves?
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
several ABS inducing panic stops on a slippery surface usually works, provided you have enough brake to drive with.
it-broke-again
Thanks for all of the replies but this has been fixed the dealer wanted 350 to open the valves in the unit so I disabled it and rerouted the brakes lines so now no abs
sergeh
bleed the master cylinder first
Andy D
10
Marshfield MA
The Rat
4.0 OHV
I replaced all the hard lines and wheel cyls , calipers, I left the rear hose and th MC, the drums and rotors I kept too. I took pains to keep the MC full. I probably used a qt in the process. Bleeding was a snap. Everything was new. I used a 2nd qt . I gravity bled by tightening up the drips as I worked from the MC to the wheel cyls. It worked great:D
voodoochylde
Rainelle, WV
2.9l
If nothing else works, it may help to pull the master cylinder and bench bleed it.
