I have a 1990 ford ranger and i swapped a manual in
bradley899
4
Georgia
Ford ranger sxt
If it had the a4ld, the nss wires are in the five-pin plug that went to the automatic.
Do I just leave the clutch pedal alone
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Ranger: 2.9; BroncoII: 4.0
No see I also have a 2001 transmission thats wht I wanted to put in it at first but I put the 2004 in e everything bolted up just fine e just do t know electrical
So the question is: was the rebuild job a good one? Is the transmission the problem or the engine?
Can I put the 2004 throttle body on it
If the 2004 is an SOHC, then no. If it is an OHV I don't know
If you have a switch then put it in( the connector is there to hook it up), if not then I would hook up the neutral safety switch from the trans
bradley899
4
Georgia
Ford ranger sxt
Do I have to find the plug that went to nss switch and bypass something electrical is the computer my problem. And just I have to plug in the clutch pedal switch or can I leave it alone
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Let's clarify some stuff:
Do you have a clutch pedal switch?
When exactly did the engine start running rough?
Edit: I am headed to bed. Goodnight;)👍😴
bradley899
4
Georgia
Ford ranger sxt
What id an injector is so lose i could get it out by hand
Josh P
50
Phoenix, AZ
You have unrelated issues. Does your engine have a maf sensor? Did you get a manual ecm? It will run with the auto but sometimes if you push the clutch in, the rpm will drop fast and the motor can die if you are coasting. I don't like to install the clutch pedal position sensor, if you ever get into a situation where you need to move a dead truck out of the road, it's easier to drive with the starter than pushing it. Someone looking down at their phone...
