I need a very long straight edge ruler...like 20'
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I am building a steel fence in sections of 3 posts between 16' foot lengths. the posts stick past the top and bottom horizontal rails, so I use a long straight edge in the jig to line up all the posts. So far the only thing available is a 20' stick of 2" square steel tube 3/16" wall thickness. Not only is heavy to use, but flexes quite a bit. I have to clamp a bunch of chunks of other stuff to it to get it rigid.
My question is what would be the best/ least flexible of size/material to use a long straight edge?
I'm thinking Aluminum would be best, but not sure on size/wall thickness. Maybe 2"x4" rectangle tube 1/4" wall thickness?
I think Aluminum comes in 21' lengths, but I could cut it down a bit if that would also help rigidity.
superj
2,663
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
A string line pulled tight makes a great straight edge. And since they come with blue or red chalk, you pop it and it puts a line where to cut.
Thats how we lined up stuff doing construction, building supermarkets and stuff like that back when i was in construction
mikkelstuff
469
Brighton, CO
3.0L
If it must be a straight edge, buy 1" x1" steel tubing. It comes in 20' sections. Very straight and way cheaper than aluminum.
When finished, you can cut up the steel tubing for all manner of projects.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
ericbphoto
Overlander in development
16,712
Wellford, SC
3.0L
6"
Laser level?
It sounds like he wants something he can clamp stuff to , as part of a building jig. I’ve seen cats trying to clamp onto a laser light beam. It doesn’t look easy.
snoranger
Professional money waster
ASE Certified Tech
13,717
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
My 3 idiot kittens were trying to get the little red dot all morning.
8,372
I got a DeWalt self levelling laser unit quite a few years ago and it really has come in handy for work and home use
Has 2 lines, level and plumb, and self levels, within reason, lol
It will flash off and on if not level/plumb
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I would try to build something from plywood, glued and screwed.
Or U channel in Aluminum - 2" x 4".
Maybe a small LVL beam?
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yea but I'm building these layed out on a bench...gravity is 90 degrees on me
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Ugh I never had good luck with wood. Too much flex.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Pleasant but I need a physical contact edge situation
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yes thank you for getting me.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Laser sights are probably illegal in Cali lol
Lol haven't bothered to check...assuming yes...everything is illegal here. By the way if you ever want play drug smuggler bring over some real menthol cigarettes...they banned those here too.
