I need chassis dimensions 1987 Ranger
EVconverter
Kalamazoo, Michigan
Thank you Krugford... yes an interesting read on the tailgate aerodynamics, I have some ideas for this Ranger, but the guy sponsoring our build is into airplanes and such, so he has the last word on body aerodynamics. We are probably going to close in the underside, at least for the battery box. And when it is done he wants to lower the hood, probably Corvettish from how I read his "hands in the air" description...
AS far as placing the motor to rear you should check this wikipedia page http://en.wikipedia.org/wiki/Ford_Ranger_EV
Ford mounted the electric motor transversely, with a transaxle transmission...
And that is one of the reasons I am considering replacing the rear suspension with a four link and maybe the 8.8 axle from a lincoln town car (as suggest on TRS axle page) or F 150 axle. That allows more room for batteries on the outside of the frame, with a side crash bar of course...
ALSO Since I am new to this site and new to blogging in general and Since I created my posting before I found Dwinmacs, and since I see 36 people have checked my post but no replies and since it is the same subject... What's the proper thing to do? Delete that post? reference it over here ... http://therangerstation.com/forums/showthread.php?t=324
move it over here?
I'm just barely computer literate... and prone to run on sentences
EVconverter
Kalamazoo, Michigan
Dwinmac, I found a drawing... indeed at a body shop that does frame straightening... it's in metric... I told him about the the project and so he wants me to drive it by when it is done. If you don't have any luck at your locality, he will lend me the page for your '87 but we will need to know short bed, long bed, extended cab, etc... and I will send it to you.
dwinmac
Syracuse,NY
EVconverter, I will check around. I may get back to you if I don't find anything. Thanks.
Wicked_Sludge
43
Westport, WA
3-point-GO
this is a very cool project and id love to see some pics of the install if possible.
could you elaborate on the clutch setup? you said the clutch is fixed to "always engaged" and is pedal-less...how does the rig shift?
is there an apx. HP rating for the motor?
another thing you guys have probably already taken into consideration, but ill say it anyway...that many batteries producing that many amps is going to produce a lot of heat. when you start adding skirts and air dams, you'll want to have at least some air flow through the battery backs to prevent heat from building up.
if this kit is as straightforward as it sounds....i might just consider it as an alternative for my '89 escort which sees mostly highway use, but only about 40 miles per day.
EDIT: never mind on the horsepower rating. if the controller is rated for 400 amps at 120 volts then thats only about 64 HP (its probably closer to 50-55HP as a safety margin).
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
when it's completed they should do a tech write-up in case anyone else desire to do the same:cool:
dwinmac
Syracuse,NY
The part of the clutch that accepts the spline from the transmission is attached to an adapter that is the same diameter as that part of the clutch and the adapter slides onto the keyed moter shaft and is stablized with a set screw through the adapter to the motor shaft. A slight indentation is bored in the motor shaft where the set screw meets the shaft for additional security. I'll attach a picture showing the clutch part as attached to the adapter.
I'm not too sure yet how all the motor parameters fit together but according to the documentation the FB1_4001A motor is rated at 30 hp continuous at 144 volts an 100 hp peak. That would use 24 6 volt batteries, this design uses only 20 for 120 volts and more like 25 hp continuous. I think the continuous amp rating is more like 200 amps but I'm not sure. I'm just getting into that aspect of the design.
I'll attach some pictures from this past weekend. The pictures are not all that great because of the size restriction the website puts on them. It is a very interesting project.
dwinmac
Syracuse,NY
As far as shifting is concerned I'll know better when we get it running and try it but supposedly you run in 2nd gear around town and in 3rd on the highway. Reverse is used to back up. I believe the rpm's are around 5000.
Wicked_Sludge
43
Westport, WA
3-point-GO
i see, so even thought the clutch disk is there, there is no functional clutch. shifting from 2nd to 3rd while moving could be tricky, but probably possible since your using a synchronized transmission.
the project looks good so far. the pics help show how the motor is adapted to the transmission and stock motor mounts.
if the motor is supposed to produce 25 HP with your 120V setup, then you'll be drawing about 155amps. that makes sense since electric motors are usually rated at their continuous HP, not their peak power (like gas engines), which can be several times higher then their continuous rating (100HP at 144V is 518A). we also have to try and remember the fact that electric motors usually produce MANY times the torque rating of their gasoline equivalent. 25HP may not sound like much, but its probably making more then 100ft-lbs of torque and at a much lower RPM then the gas engine.
krugford
Iowa
The rating of the motor isn't going to go down because of decreased pack capacity. It's just saying that you can run the motor all day at that rating without risk of severly reduced life. Your continuous rating is going to be determined more by the batteries you're running than the motor. You are going to want to know how much current you can continuouly draw from the batteries without internal damage or overheating. Putting a load across a power cell will cause the voltage to drop. This means you can't use open circuit voltages in your power calculations and higher discharge rates exponentially decrease the effective capacity. You will also want to cool the batteries by flowing air through the enclosure and, if possible, keeping an airgap between all the cells. You're not going to need 25 hp to drive down the road either. I would say you'll probably need less than 20hp for highway crusing. Stop and go traffic will be the largest factor in how far you can go on a charge. You won't want to be constantly mashing your foot on the electron pedal. That and keep in mind the system efficiencies. Lead acid batteries in good working order are going to be around 65-70%. This means if you put in 100 amp hours into the pack from the grid, you'll only get 65-70 amp hours back out depending on your driving. That and your motor controller and motor are both going to cause additional decreases in miles per charge. What do the efficiency plots of the motor/controller look like? Do you have more specs?
A switch to three phase would yield higher efficiencies, but would also increase cost significantly. I believe the best motor/controller combo in the world right now will push around 98-99%, but once again, its all about the $$$$$.
Keep the pics coming!
EVconverter
Kalamazoo, Michigan
As far as driving without a clutch... you drive it like a farm tractor, you choose a gear appropriate for the work to be performed, 2nd or 3rd (of 5) for around town, place the shift lever in position while stopped (No engine rpm (no idle)), make sure it "clicked" in, then depress the "electron pedal", gently of course... To get on the highway, you stop at the traffic light or gas station (hah) or wherever, at the top of the ramp and, while stopped, select 4th or 5th, make sure it clicked in, then go to the highway. There are several places in all the literature that I've been reading that warn against free revving, that is rpm with no load. But I think that all these warnings are in regard to over revving the motor where the centrifugal (centripetal for you young pups) will blow out the armature.
I spent 10 years as an over the road truck driver, and I learned early how to float the gears. That is, to shift the gears without using the clutch. It actually saves on clutch wear but takes its toll on the U joints, especially the first one at the back of the trans. So no matter how good a shifter you are, the wear takes place somewhere. But U joints are easier to replace than a clutch (never mind that a clutch can last 500,00 miles on a semi with a good driver). Here, in an electric vehicle, you either shift while stopped or learn to float the gears gently.
A gentleman I know used to drive for the county road commission, dump trucks with plows for the winter. The trucks were spec'd out with a 5 speed and 2 speed rear axle. Every 2 years they traded in some of the trucks for new ones. That year the new trucks arrived with Allison automatic 5 speeds with 2 speed rear... The drivers all looked at eachother with puzzled face. Can you shift a 2 speed rear with no clutch? YES... especially with all af the float available from an automatic. PLUS they stopped breaking axle shafts, which they would go through about one per week during plowing season... Soon all of the trucks came in with automatics...
