DavisRanger
- Oct 6, 2019
- 29
- Age
- 36
- Auburn, Wa
- Ford Ranger
- Engine Type
- 2.9 V6
- Engine Size
- 228
- 2WD / 4WD
- 4WD
- Total Lift
- 4” body lift
- Tire Size
- 31x10.50R15LT
I just recently did a complete rebuild on my 2.9L. Almost everything under the hood is new.
The truck idles great, but when under a load it’s missing at low speeds (lower rpm), but doesn’t miss at higher RPM’s.
I removed the cats because they were clogged and put in a straight pipe. Never reconnected my O2 sensor, but I wouldn’t think that it would cause that kind of issue.
Got the timing nailed down and have made sure all of my vacuums and sensors are plugged in (minus the O2).
I replaced the MAP sensor and now I’m thinking it could be my IAC. I pulled the codes and this is what I got.
the engine was not running when I pulled these codes.
Code 221 (if I remember right this has to do with timing, and I believe that this is from when I was setting it.)
Code 51
Code 41
Any help would be much appreciated.
Code 51
Code 41
