ignition switch
jim77885
san diego ca
My wife tried starting our 2001 4.0 yesterday, but it wouldn't start. When she took the key out, the "chiming" noise continued as if the key was still in the ignition. By the time I got home, the battery had been drained. It seems like the truck thinks it's "on". Is this an ignition switch problem?
ericbphoto
Overlander in development
TRS 25th Anniversary
16,786
Wellford, SC
6"
Can you turn the switch back and forth without the key and get it back to the "off" position? If so, the cylinder is probably worn or it's internal pins are sticking. If so, the cylinder is pretty easy to replace.
Many people have too many keys or other objects on their keyring making it heavy. Over time, this wears out the ignition cylinder and key prematurely.
This message composed solely of recycled electrons. Go green!
3,614
If the little flapper that tells the chime the key is in gets stuck, that will happen.
Should take a good while for it to drain the battery though, couple days at least.
jim77885
san diego ca
Update: Put in a new battery and everything seems ok. I'm still wondering why when the old battery was in the truck I was getting the chime, even when no key was in the ignition. I would put the key in the ignition and try to start the truck. When I took the key out, chime continued.
