- Oct 1, 2021
- 2,669
- corpus christi, texas
- ranger edge
- Engine Type
- 3.0 V6
- Engine Size
- 183 ci of tire shredding power
- 2WD / 4WD
- 2WD
- Total Lift
- none
- Total Drop
- none
- Tire Size
- 235s
- My credo
- drives a stick shift ranger
be sure to post what you learn as us other torsion bar guys would like to do the same thing.
i had seen that deal about some stock keys being different and allowing more drop but i don't recall where i read it. i did a lot of searching too. and the kit to convert our torsion front end to a coil over front end is no longer available unless you find someone who finds one in their garage or something. that is what i wanted to do so i could build an autocross truck without having to get another ranger. i pretty much gave up on that and will probably end up using another e30 bmw since i have a garage full of e30 parts from when i raced those. it doesn't seem complicated to make your own coil over brackets though and you can find conversions for jeeps that might work on our trucks. i am just hesitant to do that stuff because i don't know why. i just think it will fail and i will crash if i do it on my own. no idea why i think that
yes, hit the junkyard for stock coil front suspension ranger u-bolts when you pull the rear block.
