Inconsistent tachometer
keegan89
4
las vegas
ford ranger
This has always been a problem it has just happened a lot more often recently. 90% of the time my tachometer is reading about 1000 or more rpm’s high. very rarely is it correct. does anyone know how i can fix this? thank you
Truck is 1989 Ranger with 4.0 ohv swap 5 speed
franklin2
1,781
Virginia
What are you using as a reference to what the rpm really is?
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
What was in it before the swap?
gaz
683
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@keegan89
My timing light also displays engine RPM; if it didn't and I suspected that my tachometer was not reading correct, I would verify my suspension with a known good tach.
You could go to an AutoZone and let them take a look with their timing light, comparing the readout to your cluster tach...will they are at it.
keegan89
4
las vegas
ford ranger
i actually had my smog done recently and was able to see the rpm reading at idle and it did not match up, not sure why my tach would just randomly start acting up
franklin2
1,781
Virginia
Because it's about 30 years old? The one on my 86 ranger didn't work. Until I looked a little closer and found the needle had broken off, the tach still worked. So I superglued a wire tie I cut off onto the center hub and that worked for years. Was It accurate? Not sure, I guessed where to glue it.
Your needle may have slipped, the spring that returns it to zero may be sprung, could be anything.
keegan89
4
las vegas
ford ranger
not 30 years old, but thanks for the help
