inner shifter boot
xrs11
Deatsville, Alabama
Ok, I've been looking for a few days trying to find where I can find an inner shift boot, the one that is directly on top of the tranny, for a FM146. Finally called the local dealer, $42.98. it's a 1991 with 300k on it, I'm not going to spend that much for one.
Is there a cheaper fix?
Am I calling it the right thing at the auto parts stores?
c_note
September 2009 OTOM Winner
back in San Diego, CA
Ranger/Explorer
4.0 sohc
i went to a ford factory parts seller in OKC and they were selling the inner boot 4x4 with manual tranny and t case for $230. and it had to be special ordered.
dusto2
scv ca
2.9
i found that a tie rod boot from dorman help #13564 fit almost perfect just need to silicone the opening at the top since it is a little bit bigger then the shifter
xrs11
Deatsville, Alabama
Cool, thanks dusto2, did you get yours at a local auto parts store?
dusto2
scv ca
2.9
ya I actually work for a local mom and pop style store, we stock it here its a tierod boot for bigger tierods, if you look in the help section of your local store they should have it or be able to get it for you. It fits perfect and the bottom plate just wire tie it on , and silicone the top hole since it is a little bigger that the shaft of the shifter
rboyer
4.hoe
dusto2
scv ca
2.9
that would work and be nice if we were talkin about a m50, but we are discussing fm146 in this case and the shifters are completely different
xrs11
Deatsville, Alabama
If it would ever stop raining I would finish this clutch job!!!
rboyer
4.hoe
I totally missed the part about it being a mitsu trans.
hammerman
Culdesac, Idaho
Shift boot
Link is no longer available, do you have info on where I might get the repair kit you posted about. Most that come up in search are three bolt pattern mine is four bolt.
hammerman
Culdesac, Idaho
Shift boot
Link is no longer available, do you have info on where I might get the repair kit you posted about. Most that come up in search are three bolt pattern mine is four bolt. Fm 146
ericbphoto
Overlander in development
16,706
Wellford, SC
6"
You dug up a thread from 9 years ago. That user might not even be here any more.
Sent from my SM-G960U using Tapatalk
