Install aftermarket Door Lock Switch
redcloud
6
Mexico
Mazda B2500
2.5 (4 Cylinder)
2.5
235/75/R15
Hi, I just make electronic my door lock and they work with a aftermarket alarm.
How Can I Wire the Motorcraft- SW7080 Switch?
I already bough a used switch with harness but there are 3 cables and my door lock only have 2 (negative and positive)
Colin
182
ON Canada
Mazda
Factory is lock, common, unlock.
RobbieD
2.9l Mafia
3,553
Georgia
If I understand it right, you added doorlock actuators to the doors, and they are being operated by an aftermarket alarm system.
Can you post a picture of the aftermarket alarm's wiring diagram?
The added doorlock actuators will be operated by relays, and I need to know if the relays are inside the aftermarket alarm module, or separate.
A doorlock actuator typically has 2 wires. These rest at ground, and one will change to +12 volts positive when the locking or unlocking. Do not try to jumper +12 volts to either of the wires; they are normally grounded.
