Installing motor and aligning it with transmission
accarmonaa
i pulled the motor out to rebuild it and now im installing the motor the transmission is still bolted to the crossmember and drive shaft what is the easiest way to get the two to line up sp i can bolt them together
1986 ford ranger 2.3 fi manual 5 speed
black_demon69
142
AZ
4.0l
pull trans and line them up outside of truck. then install them both....
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It's been a long while [~35 years] since I've installed just an engine. There is a lot of pushing and swearing and pulling and swearing, and did I mention swearing.... I've never done an inline.
Maybe pull off the motor mounts temporarily so you have a straight shot at mating the two. Having an adjustable sling will be helpful, it allows you to change the angle of the engine as it is going in. More than one person helps.
If you can't get it, then the above suggestion has merit.
Good luck,
Richard
scotts90ranger
4,440
Dayton Oregon
2.3 Turbo
I don't think there's enough room to pull the engine and tranny together even though people say to... it doesn't make sense to me as it's not that bad... 2.3L's are long...
Anyway, I've done mine a couple times by myself and it isn't all that bad, stick a ratchet strap over both frame rails and under the front of the transmission, use this to get the tranny up most of the way. Now lower the engine in most of the way until things start getting close, get the input shaft of the tranny lined up with the pilot bearing of the engine and muscle them around until you get them close to see if you can get the alignment pins to go where they are supposed to be. if that doesn't work put one bolt in on each side of the engine to pull them together, be as even as you can and it should work out. If manual transmission after you get the input shaft in the clutch you will probably have to turn either the engine, the transmission, or the input shaft (put it in 4th gear and turn the driveshaft). Like mentioned, it involves swearing, but it's very doable.
