Interesting observation on the 2.9L
2trux
16
Albuquerque NM
2.9 L
When I pulled the engine from my Ranger to rebuild I discovered the thrust surface on the crank was worn badly and allowed a lot of front to back movement in the crank. I had to have the crank welded and ground to spec.
It seems that Ford thought it was sufficient to have a thrust surface only on the upper half of the bearing.
Fast forward to Saturday and we pulled the 2.9 from my sons 90 B2 to rebuild. His has the same issue with the crank end play. After some brainstorming with my brother we decide it must be because of pressure put on the crank when the clutch is engaged. With only half a thrust bearing the wear on the crank must be excellerated. Both these engines have a jillion miles on them so maybe it's to be expected.
To test our clutch theory, and perhaps find an engine without the problem, I headed to the local pull-n-pay. I found 2 trucks that were automatics and a couple that had manuals. The end play on the engines with automatics was minimal and the end play on the manuals was more like what my 2 engines had.
Has anyone else noticed this, or am I the only nut who is rebuilding high mileage 2.9 engines?
My conclusion: if you are going to get one of these engines to rebuild, get it from a truck with an automatic. So this weekend we will be heading over to pull-n-pay to buy the short block from one of the trucks with the automatic.
Mike Tonon
Guest
Interesting
I like the 2.9's, had one in my old 87 Ranger. Had some little issues, but nothing serious. Never burned any oil and the only oil leaks were the valve cover gaskets before I changed them. It had a manual, but I didn't notice this shaft issue.
PAWGEdward
Ohio
2.9
I just had the same problem and was told to get my transmission rebuild or the pressure my current trans is putting on the crank will cause the thrust surface to wear again. I have an automatic. Can't remember the persons theory as to what is wrong with my transmission but I figured its not worth throwing more money at it and im going to make it a project truck with a 302.
So it can happen to automatics also, but seemed like it could be solved with a new one or a rebuild.
kunar
131
Toledo, Ohio
5.8l
My dad bought a b2 roughly 10 years ago that had this same problem, though the truck was an auto truck from the factory. Somewhere around .070” endplay in the crank. It sounded like a tick or a knock when it ran. The truck now has a 4.0 and a manual.
Worst city, Pennsylvania
1957
1999
how many miles do you think it takes to get significant crank walk? I've got a 2.9 with 155k on it originally a 5spd.. currenty is auto but thinking of throwing the fm146 back in it.
2trux
16
Albuquerque NM
2.9 L
That is an interesting question. Both my engines were very high mileage. Mine was listed as having 470K and my sons having 285K miles. Of course there is no way to tell if those were still the original engines, we have owned them for less than 6 months.
Do you have a dial indicator to see what your end play is now?
1957
1999
no, lol unfortunately. i put about 10k miles on it with the auto.. wishing i had thrown the fm146 in.
2trux
16
Albuquerque NM
2.9 L
Well I had a successful raid on the pull-n-pay. Found an engine from a B2 with automatic. The end thrust on the "new" one was .008 as opposed to .055 with the "old" one. This one also has good looking bearing surfaces and very little cylinder wear. We plan on just doing a bearing and ring job on this.
The boy is happy to save some bux, and this should keep it running for a few years.
