Intermittent ABS light causing truck to stall
Three6ohchris
Vancouver, WA
V6
First, I have a 2000 Ranger XLT 4 x 4 3.0 V6.
So for the last month or so, my ABS light has been coming on sporadically. At first it would just be the light, it would come on and then just stay on. After a while though that stopped happening and the light would just come on for a minute,then my speedo would rev all the way up then go down to zero and then go back to normal and the light would come off. Now it will do that but it will also act like the truck dies. If I'm driving at a decent speed there's this little hick up then when the light turns off everything is normal. If I'm going slower the truck will buck and feel like it's not wanting to keep going and if I'm going slow enough it will flat out die. Doesn't seem to be any rhyme or reason to the light coming on... sometimes it'll do it if I hit a bump, sometimes I can be going on a flat road. I replaced the ABS sensor on the top of my diff. Even replaced the wire harness. I checked the square wiring plug underneath my seat under the truck for corrosion. Is this issue something that could be caused by the front ABS sensors as well? That's my next stop but I just wanted to find out if anybody could offer some suggestions. I have checked their connectors near my bumper but not at the hubs. I've done research to try and figure this out but I haven't seen anything to tell me that it was coming from the front end because of the speedo issue and I haven't seen anybody say anything about the stalling issues I'm having.
Any help or thoughts and suggestions would be really appreciated. I'm about to trade this thing in because I just can't take the problem that's causing me anymore. It's been one thing after another it seems like. I love this truck but I don't think it's worth the headaches anymore.
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
That is an interesting gremlin. Sounds almost like a bad wire or something. Only thought I have this early (haven't had my coffee yet) is related to the ABS recall. Does your truck have the repair harness? It is typically zip tied to the brake master cylinder for trucks with 4-wheel ABS. I think there are a couple fuses in that repair harness, might be good to see if one is bad. If you don't have the harness, go to your local Ford dealer. I just got it done on a 2000 Ranger that I recently got.
Sent from my kite using a trebuchet
Three6ohchris
Vancouver, WA
V6
That's a great place to start, thank you. I'm not sure about the recall part, but I'll pop the hood and take a look.
Could a short in wiring anywhere in the truck cause this? The guy who owned the truck before me did a real number on this thing and there's so many splices and "fixes" in this truck that I'm sure there's possibly a short somewhere. This and light issue has gradually gotten worse, to the point that it's barely driveable sometimes. I did blow the #26 fuse for the GEM module last week, but I replaced it (the fuse) and everything seems ok there. Anyway, it's got a New alternator and battery, I just don't know where to go from here.
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
Shorts and bad grounds can cause all sorts of problems. It drives me nuts sometimes seeing the wiring butchery that often happens. It's not cheap to get it done right, and most people don't seem to know how to do it right, so they make a mess. In my spare time I do some boat and trailer wiring repair
Three6ohchris
Vancouver, WA
V6
Well I'm crossing my fingers because I think I might've actually found the problem. There's a wire harness that runs next to the battery but comes up near the ABS that was resting on a piece of the battery tray and it looks like it rubbed through and grounded out. I moved it and taped it up and I haven't had an ABS light since. Of course it's only been about 10 miles in 15 minutes since, but still. It's the small victories. If I can figure out how to post pictures on here I'll upload them so you can see the mess that the guy made for me and the part that was grounding out in case anybody have similar problems in the future.
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
Yup, looks like it was grounding out there. Also looks like you have the ABS recall harness on there, so no worries there
Three6ohchris
Vancouver, WA
V6
Well, thank you very much for your help and thank you for confirming that I have the recall harness.
