intermittently runs super rich
ford01
two rangers and
My ranger runs super rich intermittently, getting worse and more often, going down the road it starts bucking with loss of power and blows bug clouds of black smoke, then all the sudden it takes off and runs great but only for a few minutes. I did a koer test and nothing. Anyone have any suggestions? Please!!!
8,372
The Fuel Pressure Regulator(FPR) on the fuel rail has a vacuum line, remove this line and check if for gas or gas smell.
FPR diaphragm can leak and raw fuel will be sucked into intake via that vacuum line.
You may have a fuel injector sticking open.
Hard to pinpoint that issue.
OHM test on injectors should show between 11-16ohm, but that test is for a dead injector.
Sticking injector could be a broken spring, no test for that.
Also the fuel injectors get 12volts when key is on, the computer opens them by Grounding them
You should have Batch Fire injection, than means the computer only has 2 Ground wires for 6 injectors, so computer opens 3 injectors at the same time.
My wiring diagram shows a Light Green/White stripe wire as one Ground(injectors 1, 2, 4) and a Tan/Red stripe wire as the other Ground(3, 5, 6).
IF....Big IF, one of those wires was chaffed and was intermittently Grounding to engine, firewall, body, etc.........then 3 injectors would open at that time, flooding engine.
You can pull off an injector plug and test for a ground while moving wires around.
Next is the computer, pop the top and have a look inside.
Good info here on pins and circuit board: http://www.auto-diagnostics.info/ford_eec_iv
jchris36
Olympia, WA
Explorer
2.9L V6
My truck was doing something similar, my O2 sensor was bad and that fixed the problem, it's been running better than ever.
ford01
two rangers and
Thanks guys, ill try that stuff this weekend
sjr53
Grand Forks North Dakota
2.9L
Also make sure that the orange wire that should be attached to the rear of the passenger side head is getting a good ground. That will give those exact symptoms.
