bnrr
- Mar 16, 2010
- Reaction score
- 0
- Make / Model
- Ford
- Manual
What is the piece of metal that holds the weather door seal? On my 96 ranger the weather seal is not on the door but on the door frame. There is also no seal on the door (top and side)
The only rubber seal on the door is on the bottom or underneath the door.Ok.. my problem is this, the weather door seal is installed inside of the door frame ( not on the door itself ) the seal is held in place by sheetmetal or something else, weild to the door frame. If I remove the
seal the sheetmetal that holds the seal in place will all fall out due to rust and when that happens there will be nothing to hold the seal in place, this is for both the driver and passenger side. I need to replace both the door seals because of leaks. When it leaks during
raining season, the passenger side is flooded while the driver side is just a small amount of water. The help I need is just specs information for the metal to hold the seal on the thicknesses, what kind is it and so forth. I have check the junkyard, but the design or the location of the seal is different compared to my ranger. 97s and later rangers the seal is installed by panels not mine. Did anyone in TSR encounter this kind of problem? Please help.
