It's alive!
chrisser
Cleveland OH
2.9
Last night, I started the Ranger for the first time in a few months after tearing apart the top end, replacing one head and swapping in the M5OD.
Couple issues I need to work through. I have an exhaust leak at the manifold I need to take care of, the distributor is a tooth off (I can time it, but I don't like where the distributor harness ends up), and the starter won't disengage.
But I have good oil pressure, no lifter noise and no lower end noise so far and it runs pretty well when the timing's close.
Still have a fair amount to do, but there's a chance it will be on the road again this weekend...
chrisser
Cleveland OH
2.9
Got the timing set after putting the right starter in it.
Runs pretty well.
Idle occassionally stumbles so I have to do some reading about that. Other times it idles very nicely.
Still have some lite lifter ticking. Better than before I tore it apart, but I suppose there's nothing I can do short of a full rebuild. Doesn't seem to hurt anything.
I've got a little ATF in the oil. Going to run it up to temp a few times in the garage, then change the oil out and hopefully take it for a spin tomorrow.
Still have to hook up the driveshafts, and a bunch of little things.
Feels good to have it running again. We're having some warm temps (high 40s) today and I should be able to pull it out and work on it in the sun instead of cramped in the garage.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
