James Duff Break Lines
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
I got a set of James Duff break lines this last week and got them installed.
everything fits great.
Thy are made by Earl's Performance Plumbing.
I like them alot better than the Procomps (another repackaged Earl's Performance Plumbing there name is right on the line) I installed on my brother Ranger. I'll get some photos of them soon so you can see them.
I hope this helps.
Here are the James Duff photos
86MUDRCJ
8
Sheridan, CA
Do they come with the length that you need? ANd does everything come with them? I lifted my ranger 4" and i don't know how much and what I need to finish up the brakes ASAP thanks
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
I just put a leveling kit on my 87 truck with dual piston brakes.
I put the same kit in my brothers 88 truck with a 4inch lift and there way plenty there
8879ford
i see that you have drilled/slotted brake rotors. How do you like them? Did you notice any differance?
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
I like them
Thy don't seem to fade as fast which is a plus
modelageek
14
Boston, MA
I hope this helps.
do they make ones that replace the solid lines that run to the rear?
modelageek
14
Boston, MA
I am a little confused.......can I buy a kit that would let me do all of my existing brake lines in this flex tubing?
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
No it's just for the flexible rubber lines. when you do a lift you will need longer lines
modelageek
14
Boston, MA
oh.thanks......do they sell a flex line with fittings that I could use to replace my hard line that runs to the rear brakes........
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
they do, but it would cost you quite a lot of money. the stainless line with AN fittings on the ends are about $25 for a 24" length, so if you needed a 30" piece to go from the brass T to the drivers side and another 30" piece to go to the passenger side you would be looking at roughly $60 versus about $10 to just replace the hard line with hard line. i used earls adapter fittings but i bought AllStarPerformance hoses because they were less expensive than the earls hoses.
Irokranger93
Michigan
3.0L
hey nice dude, really need to do to get my 93 that is, thank you, let us know
