James Duff Traction Bar Install
85_Ranger4x4
17,953
SW Iowa
It might be good to add a note that Duff does now build a kit specifically for 98+ trucks, product code 5306
Article is good to show the differences between the two kits though.
I may inquire at some point if they will kitbash and sell a "kit" with the older front brackets and the rear brackets for a 31 spline 8.8 (which is included in the 98+ kit)
Lefty
1,888
Saint Paul, MN
Ranger Edge
Are you pleased with the ride?
85_Ranger4x4
17,953
SW Iowa
I inquired about the kitbash thing, never heard anything back and never pursued it farther.
I instead removed the factory 4wd lift block on my Ranger to reduce spring wrap.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
I have them on my 2011.
Worth the money.
The 98+ kit fits the 2011 with the Bronco brackets (included). 2009-2011 ranger uses a 31 spline 8.8 tube with 28 spline axles.
Lefty
1,888
Saint Paul, MN
Ranger Edge
I would imagine they help to stiffen the sway bar and calm things down on washboard roads.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
By quite a bit as well.
My situation is a bit different than @85_Ranger4x4 - 1750 lb springs, late model low profile blocks, lift shackle, 4° axle wedge, B2 2wd sway bar. But, they help a great deal.
85_Ranger4x4
17,953
SW Iowa
Worth the money.
The earlier kit has a different front bracket and only comes with the smaller axle bracket.
Lefty
1,888
Saint Paul, MN
Ranger Edge
Worth the money.
I took your advice. Yup, worth it for me at least. The shifts are smoother and I get improved traction on rougher surfaces. Thanks!
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Theyre quite good overall. Tight corners with them and a LSD with the Mustang track clutches makes for a more better driving experience
Josh B
1,988
Oklahoma
MUCH more better! :D
