eb89
- Jan 22, 2009
- 0
- Ford
- Engine Size
- 2.9
about two days ago my truck was runnin fine until i hit 4th gear and sometimes in 4th it was like the engine wasnt gettin enough gas or something cuz it would just cut off until i hit the clutch or took it out of 4th completely. now it is doing it more frequently and in basically every gear. itll drive fine for a couple minutes sometimes but then it just starts jerkin as the engine will just cut out then when i take it outta gear or hit the clutch the engine will cut back on and the rpms will go up. sometimes when i try to rev it also in order to keep the engine running, i cant even really rev it. the rpms will just stay the same and it sounds weird. somethins definately up though and it sounds gas related to me but i dunno. i appreciate any help cuz i need to get this running asap if possible
i've had a similar problem to this and when i replaced my ecu it fixed it, but that was only a couple months ago so i wouldnt think my ecu would've gone bad already
