Just changed TFI module need help
88 XLT Ranger
Pollock Pines Ca
2.9L
This is a long shot, but have you checked the timing on it? The popping you describe sounds to me like it could be a backfire. The low power reminds me of the Subaru Justy I had many years ago. With the timing set to spec, it wouldn't go over 50MPH. With the timing advanced, we got it to 70MPH.
There's another possibility that occurs to me, too. What octane is the fuel you're using? If your fuel octane is too low, your engine will ping.
I found some interesting info here: http://nastyz28.com/forum/threads/getting-pinging-under-load-is-this-timing-too-aggressive.157194/ It's a GM thread, but the information may still apply. He's pinging under load, too. And this: http://www.chevyavalanchefanclub.com/cafcna/index.php?topic=4016.0 Another GM thread, but also pinging under load.
Hope this helps!
Thank you so much 1990RangerinSK
I appreciate all your info and help my timing is correct it was inspected when I did the CA smog test. Today it ran perfect until I came home down a highway grade when I coasted than turned off and started up the off ramp it started miss firing its like when you cross wire a car real bad. The lifter nose was very little that is the strange part. When I rev it up when warming it up in the morning I can hear a faint clicking snapping nose in the one valve cover. If it is a lifter I wonder if one could adjust the rocker arm down make like a solid lifter it maybe more than one lifter. I did try Cheveron supreme fuel high octane no change. The strange part is it runs perfect some day's and crappy others it is an on and off deal
bf750
12
Ky
2. Crap
It is what it is
get a 5.0 and drop in it
88 XLT Ranger
Pollock Pines Ca
2.9L
I wish it was that easy :) I have California smog laws there stiff and a bunch of BS. This pile of shit ran great today some 6 miles up hill got to town I noticed steam coming out from under the hood. It had blown the coolaint out from the top of the radiator cap. I also noticed the upper and lower radiator hoses sucked together. I bought a new cap lucky an auto store was there filled the radiator installed the new cap ran fine got back home the lower hose was sucked together WTF I was pissed. I took my other Napa radiator cap took the rubber off the lower spring seal as to not make a vacumme anymore. Now it does right pulls water in and out like it should temp stays normal
