forgey4x4
- Feb 16, 2014
- 0
- Washington
- Ford
- Engine Size
- 2.9l both
Well where to start, 89 ranger 2.9 manual 4x4, the starter has been grinding ever since I have bought truck, new starter still same problem, checked ring gear when I fixed slave cylinder it looked fine. Just got truck back from alignment and noticed that it still had some pretty bad steam boat steering, so checked the rag joint, and the baby universal joint tiny play but not enough to cause the problem so time to replace gear box. Well after I finished turning the wheel back and fourth through a whole episode of magnum pi, I decide to crank over a few time with coil disconnected and to my surprise I had no grinding starter noise at all, so the only difference That would be from normal is that the steering linkinage is not connected and there isn't a cap on power steering pump. So I crank it over a few more times just to make sure my noise is gone, and it is so cool. After putting it all back together the noise is back when I first started it it shook the whole engine and didn't want to start finally after trying to limp it to life it fired and ran fine. So I geuss what my question is could the pressure of my power steering pump be making my engine bog down enoungh to make my starter grind? Sounds weird to me but that was the only difference, besides tie rods and drag link, but no way it is them
