Leaf slung d30, what model and year of jeep should I look at?
n_bannerman
Walla Walla, Washington
2.3
I know everyone says d30 are crap but all I will be doing is snow wheeling and dding it. What year jeep and model should I be looking at?
4.0B2
151
Walls, MS
4.0 v6
For the "strongest" d30. The 94-99 xj's. I think that's the years. Has the larger ujoint shafts and high pinion with no CAD disconnect crap. However they are set up for coils and control arms. Verify those years. Find out what years are high pinion and the larger ujoint shafts
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
I just don't get why people want to use leaf springs on the front axle???
n_bannerman
2.3
It's easy and simple. Other then the shock mounts and spring pads it's almost bolt on.
n_bannerman
2.3
I'm also not going for tons of flex, I'm trying to keep it under 4" of lift if I can.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
You have to do at least 4 inches of lift to safely keep the differential from hitting the engine crossmember. Plus it's easier to do coils since your truck is already setup for them.
Hagan
11
Salem, OR
2.3
Like he said...it already has coils. Just think it would be easier but if you want to go with springs then go for it!
I don't ever recall seeing a d30 with leaf springs. But i'm sure it would be easy for you (since your considering an SAS) to weld on some spring mounts and go from there.
Good luck!
4.0B2
151
Walls, MS
4.0 v6
a lot of the t-bar guys do leafs since they don't have coils already..
OP- look at dangerrangers build, or kroussinoffroads mazda build, or escort_gts's (both of them) ... and see whats involved w/ a d30 swap w/ coils. you'll be happy you did it over leafs. only thing is, long arms ain't cheap.... Rusty's Long arms will cost you like $500 (for a cherokee). but for flex/ride/control it'd be worth it. plus the axle and truck are set up for coils and control arms (ra's on the truck)
bmxnick7
ranger xlt
All Cherokees are coil 88 to 96 the same. 97 to 99 use the bigger u joint. They are all high pinion. Yj wranglers are d30 leaf spring. Use the smaller u joints.. I would just use a 97 to 99 Cherokee. They can be had pretty cheap around me. Just grind the coil buckets and everything off. And get some ballistic fab spring perches
4.0B2
151
Walls, MS
4.0 v6
order from ballistic if you wanna wait a year or so to get your stuff.
order from ruffstuff :icon_thumby:
and there's the years you want. 97-99. (2000 started low pinion, weaker and well, its low so less clearance)
bmxnick7
ranger xlt
Guess I had good luck with ballistic. I always got my stuff within a week.
4.0B2
151
Walls, MS
4.0 v6
not to make this thread about this...
but you're one of the few. i know several of the guys on here (including myself) have been left waiting for months for something. i ended up ordering the same thing from ruffstuff and got it in a week...and still aint got my ballistic order (finally got my credit card company to refund the money, i couldn't get ballistic to help me at all w/ my problem). so from my personal experience i say avoid ballistic.. and pirate doesn't even have them as a vendor anymore b/c of customer service issues.
bmxnick7
ranger xlt
Yea I knew pirate dropped them for that. Next time I need stuff I will give ruff stuff a try
bmxnick7
ranger xlt
On another note. I think I have a set of spring perches with the weld on ends that I bought and never used
Alix
Michigan
5.3 Turbo
Careful with 99 cherokee axles. The started the LP halfway thru the year
