- Mar 4, 2010
- 17
- Omaha, Ne
- Duh
- Engine Size
- 5.0L, 2.9L
So i have some to find my rear passenger side brakes are leaking. If i press on the brake pedal with the car running you can watch the brake fluid flow out of the drum. I opened it up to see if i could spot where it was leaking from, but everything was covered in black gunk and i didn't have the time that day to tear into it. So i am thinking the only two things at the drum that could leak are the brake line and the wheel cylinder. If need to replace the wheel cylinder, do i need to pull the axle shaft?
