Led Daylight Running Lights
OkieGentleman
Oklahoma City, OK
3.0 L V6
Fix it like it has to last a 100 Years.
Where can I pick up a switched circuit (under the hood) to connect some LED light sets that I want to use as Daylight Running Lights.
Or do I have to tap off of a fuse in the interior fuse box at a "hot when ignition on fuse" and run a wire thru the firewall? If so where is the best place to put a wire thru the firewall?
I have searched thru both of my manuals for an answer.
Thanks for any advice.
OkieGentleman
Oklahoma City, OK
3.0 L V6
I guess it would help if you knew what vehicle.
1998 Ranger extended cab with suicide doors.
Which thanks to this forum I repaired for about $8.00 instead of $700 at the dealers.
I also modified the front side light to be part of the signal system. It looks good and I like the way operates. Thank You to the members that put that information on the forum.
