lets see where you put ur cb radio?
sbsrlewis
4
Shawnee, Oklahoma
is this clean enough? if you take your time and measure twice, cut once, it can be made to look like it belongs there.
steve
4.0B2
151
Walls, MS
4.0 v6
that's fine. looks great.
but others don't take that much time into it. for them it may not matter. their rig, their choice.
AND---- that radio is a great choice for that since it has a front facing speaker built in.
sbsrlewis
4
Shawnee, Oklahoma
thanks. i thought the same about the radio with the speaker in the front but i had removed the carpet and had the floor Line-X'd so it's loud at highway speed so i added an external speaker.
steve
sbsrlewis
4
Shawnee, Oklahoma
external speaker = problem solved!
steve
4.0B2
151
Walls, MS
4.0 v6
The speaker on the bottom of my dash is hooked to both my cb and 2 meter. Which solved my speaker trouble with only 1 speaker! Instead of having 2 hanging around
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
Mic is on a gear keeper hanging on the mirror. Linear is under the driver seat. External speaker is behind the arm rest in the middle of the two seats.
86Ranger Nathan
1986 Ranger XLT 2.9L V6. Running a Cobra 25WX/ST. Mounting bracket simply screwed in underneath the dash. Mic hook mounts to the side of the radio and mic cord loops around gear shift. Doesn't interfere with gear shifting at all. First pic is with gear shift in Reverse. Second two is with gear shift in 1st.
Foxracin
4
Mount Holly, NC
Josh40601
MTOTM Winner
12
San Diego
Ranger is mounted in the cealing like John's, and the Ex is on the floor with an external speaker on the ground too pointed towards me... To bad neither of them work :( <- Starting a thread on this right now....
Tbmitchell
Chillicothe,ohio
Go Big Or Go Home
I Build A Custom Mount For My Cb My 2 Meter 440 Ham Radio And The Kicker Amp For My CB Dont Mind The Black Screw They Were Free Thanks To Kenworth The Big Truck And The Diamond Plate We Had Just Laying Around
Nate W.
August 2012 OTOTM
1989.
FORD
2.9L V6
Antenna mounted by a hood-bracket. About $10 for the bracket.
CB mounted under the ash tray:
B2 Addict
9
Lavergne, TN
Solid Axle Swap 4x4
37x12.50-17
tony314
Firefighter
12
St.Louis Mo
I'm going to get another one soon for the new ranger. I'm wondering if the space between the visors will hold a CB on my ceiling?
4.0B2
151
Walls, MS
4.0 v6
i'm switching to a cobra 75 setup... so only that little hidden box has to be mounted, which will be mounted under the seat. all the controls are in the mic
88ranger89camaro
Firefighter
Squaw Valley, CA
2.3
Great to see someone else running a "real" radio
