Lift help
lilred_84ranger
Cadiz,ky
ford/ranger
I know there is different types of ways to lift a ranger I want to know what is the best way to lift my 84 ranger? Should I go with a kit? Does it come with everything I need?
gaz
674
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@lilred_84ranger ,
Both a body lift and suspension lift have different advantages, depending on your timeframe, budget and end suspension needs.
For a superior ride quality, I prefer a 4" suspension lift but if all that is needed is more room for larger tires, a body lift will do well enough.
SenorNoob
598
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Cadiz, KY... You're literally right beside the Fall Round Up site.
I see this is posted in the 2WD section. Not a whole lot of people lifting 2WD trucks here. What are you looking to do with it?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I had the same question...
Is this 2WD?
I'd like to move it if it's a 4WD.
Lefty
1,896
Saint Paul, MN
Ranger Edge
Google Bell Tech Lift Kit for Ford Ranger. They are a solid reliable supplier.
lilred_84ranger
Cadiz,ky
ford/ranger
want to lift because I’m hoping when I lift I’ll be able to spray the frame with por15 and get larger tires when I’m done with it I’ll take it to shop to painted and wrapped
Lefty
1,896
Saint Paul, MN
Ranger Edge
Sounds like a great plan! I would add that POR15 is merely a primer and needs an equally durable top coat. Do keep us posted as you go.
SenorNoob
598
Middle Tennessee
245-70-R16
If you're going for easier access to the frame, gotta recommend a body lift. Especially for a 2wd. I'm not sure what the market is like for suspension lift options on a 2wd.
superj
2,706
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Belltech makes a 2wd kot for rangers. I was on their site yesterday
Lefty
1,896
Saint Paul, MN
Ranger Edge
I've got some old 2" lift blocks from a 2003. I'm not sure if they would work on yours. You can have them for free. Just pay the shipping.
mikkelstuff
469
Brighton, CO
3.0L
Gosh, I was going to recommend a floor jack!
