lighting problems
MUDDING B-3000
Barrie, Ontario, Canada
Ford , Ford
7.3L , 4L
well i went to work on my project truck yesterday, an found out that now my brake lights work. well the back running lights work, but nothing happens when i hit the brake.
also only my passenger side front signal works an none of my other signals work. so what could that be? it all worked perfectly about a week ago so.? an the truck has only sat in my garage. maybe a loose connection. something not grounded right?
martin
26
St Bruno, Quebec
1991
What happens when you put on your four ways? what colour are you rear turn signals? The only common area seems to be the multi function switch.
MUDDING B-3000
Ford , Ford
7.3L , 4L
when i put my four ways on just the front passenger side blinker flashes. an my rear turn signals are the red brake lights, an where is the multi functon located? its for my 92 ranger.
thanks
MUDDING B-3000
Ford , Ford
7.3L , 4L
so i checked all my fuses an they all are good so i dont know what it could be?. do i have to check over the whole truck an make sure everything is grounded right? cuz i dont understand how one day it was working then the nxt it stops? an not a blown fuse.
Roadkill
Ontario, Canada
7.3l turbo
Check all your connections for the green growth of death (aka. corrosion). I've had a light connection go bad on a trailer that was fine within a day while driving the rig. This weather with the warm and damp then cold will cause some issues.
MUDDING B-3000
Ford , Ford
7.3L , 4L
ok thanks alot ill check over all that while its nice out.
