Limited to 3k RPM?
kxri318
28
Ohio
1986 Ranger 2.9 auto 2WD. I floored it for a couple seconds or so while driving yesterday and it's like it hit a 3k rpm wall. It stuck exactly at 3k and held it; didn't go over that at all according to my tach and also what I was hearing. Doesn't affect normal driving at all because I rarely go above 2500ish rpm when getting up to speed, but was curious why this might be happening. I didn't see if it gets stuck at 3k in park/neutral.
rusty ol ranger
2.9 Mafia-Don
7,503
Michigan
177 CID
Was it missing or anything? Or would it just not go higher?
8,370
Does speedometer work?
Clogged exhaust can limit RPM, as can clogged fuel filter
But 3,000RPM is pretty specific, its the REV limiter RPM when speed is at 0MPH or computer thinks Automatic trans is in Neutral/Park
kxri318
28
Ohio
The speedometer works fine, but I can't lie, I haven't checked the fuel filter once in my 2 year ownership of the truck. Fuel pressure at idle is a good 30-40 psi though. Exhaust is the same diameter pipe that it came with and the cats are gutted.
rusty ol ranger
2.9 Mafia-Don
7,503
Michigan
177 CID
I dont think a 2.9 has a rev limiter.
The spedometer works fine, but I can't lie, I haven't checked the fuel filter once in my 2 year ownership of the truck. Fuel pressure at idle is a good 30-40 psi though. Exhaust is the same diameter pipe that it came with and the cats are gutted.
30-40psi is perfect.
If it was a fuel issue it would sputter.
Cats are a non issue...so rule that out.
Its weird it doesnt miss or anything.
Maybe a weird distributor or TFI issue? I honestly dont know.
Is it timed correctly and the SPOUT connector plugged in?
kxri318
28
Ohio
I think it was just a fluke. I near floored it today (for science and definitely not for fun ;)) and it went from 1800-3800 then shifted fine. To answer your question though, it's timed right and the spouts plugged in
rusty ol ranger
2.9 Mafia-Don
7,503
Michigan
177 CID
Eh run it see if it does it again i guess
