Links to wiring threads please
kevinbmx77
Needs some link for threads on wiring a 302 into a v6 ranger. Ive found some good one previously but cannot find any of them anymore
Sent from my SM-G920P using Tapatalk
kevinbmx77
From what im seeing in my own wiring its these three connectors going to the injectors that need to be swapped?
or do i need everything from computer to injectors?
What do i do with this big round plug?
I'm lost and don't want to resort to a carb after everything
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Check the tech articles
kevinbmx77
Anybody? I'd like to start my swap this weekend and cant find the info
kevinbmx77
I've got these
But the big round connector is tied into the same harness as my computer, how does that work? Do i need to pull a mustang harness and a ranger harness and tie them to each other?
Elutheros
129
Central Texas
Here is a link to some of the wiring diagrams you may need. You will need to remove the V-6 ECU and associated wiring and use the V-8 ECU and wiring to the engine and sensors. I'm not sure when they changed from the 60 pin ECU to the 104 pin ECU--that's something you will have to research. If you have the 60 pin these diagrams will help http://www.veryuseful.com/mustang/tech/engine/#Diagrams
